Old Jul 22, 2015, 7:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Trying to program key fob, 1999 Chevy Silverado 1500
Old Oct 11, 2012 | 7:23 PM
  #11
BostonCelticsBanner18's Avatar
Originally Posted by Doug Roberts
you have to jump obd2 port to 4 and 8 and turn key on oof three times then hold down lock and unlock i believe
i have same truck my problem is finding a key fob
Nah, I tried that...
There isn't even anything in (port 8 I believe) I tried that.
Old Oct 12, 2012 | 2:34 PM
  #12
spyncycle's Avatar
Check this site. It has free programming directions for lots of vehicles.
Free Keyless Remote Fob Entry programming instructions, procedures for all automotive vehicles
Old Oct 16, 2012 | 12:33 AM
  #13
Appreciate the help, but it's not like I'm doing the procedure wrong.
I'm just convinced the truck doesn't have the option for some gay reason
Old Dec 3, 2012 | 11:12 PM
  #14
99 Silverado 3 door's Avatar
Default Programming the key fob
Hi Guys,
I got this from my 1999 Silverado owner's manual:
"To resynchronize your transmitter, stand close to your
vehicle and press and hold the LOCK and UNLOCK
buttons on the transmitter at the same time for seven
seconds. The door locks should cycle to confirm
synchronization. If the locks do not cycle, see your
dealer for service."
Also the manual says the battery is a CR2032 3 volt.
Hope this helps.
Old Sep 19, 2013 | 6:18 PM
  #15
Bradley D's Avatar
i'm working on a 99 gmc z71 that doesnt have anything in port 8 or 1 wtf ?
Old May 4, 2018 | 11:11 PM
  #16
jfayadjr's Avatar
I am also having an issue programming my remotes. I tried holding down the unlock button and cycling the ignition (on-off-on-off. Nothing. I tried the jumper wire way but my ODB2 port does not have a tab in the #8 spot. What now???
Old May 5, 2018 | 4:12 AM
  #17
1. Start with ignition off.
2. Press and hold unlock button on drivers door, the locks will cycle once.
3. Turn ignition on-off-on-off.
4. Release unlock button, the locks will cycle once.
5. Hold down lock and unlock keys on keyfob transmitter until locks cycle (about 15 seconds).
6. Repeat step 5. for remaining keyfobs (up to 4 total)
7. Turn ignition on to exit the programming mode. Programming is now complete
On step 5 you have to hold down the unlock and lock buttons on the remote at the same time till you see the doors lock then it will be complete.........
I just reprogramed my 99 xcab remote with this procedure and it worked
Hope this helps......
The above instructions were the ones I used. I don't have a 99 xcab just a 3 door 99 Silverado
Also when I did mine it took up to 30 seconds for it to program while holding the key fob buttons.
I also thought I was doing it wrong but by holding both lock and unlock buttons, which seemed like forever, it finally programmed.
Last edited by 99 Silverado 3 door; May 5, 2018 at 4:34 AM. Reason: Add corrections.
Old May 5, 2018 | 10:29 PM
  #18
jfayadjr's Avatar
Default StI'll doesn't work
Did everything. Even held the remote buttons for a full min. Still nothing.
Old Jun 11, 2018 | 6:18 PM
  #19
robin renfro's Avatar
I'm having the same problem did you ever figure it out please let me know thank you
Old Jun 11, 2018 | 6:19 PM
  #20
<br />I'm having the same problem did you ever figure it out please let me know thank you
