Upgrade brake pads and rotors?
I will be needing new brakes on my truck in the near future, it a silverado 1500. I was wondering if anyone could tell me if it is worth the extra money to upgrade from stock to performance pads and slotted rotors, something like EBC or similar. I dont usually tow trailers but I want to be able to stop with a trailer on when I need to. Any input would be much appreciated.
If you really want to do some brake upgrading, then get 05+ silverado front brakes, make sure you get the ones that have drum brakes out back on a 05 model(13" dual piston instead of 12" dual piston fronts) and 05 suburban z71 rear brakes(13" dual piston instead of 12" single piston). You'll need the rotors, brake pads, and calipers/caliper brackets for both of them. These you can get at auto parts stores. Most carry loaded calipers that have the caliper/bracket/and pads in one.
MIKE1950
July 31st, 2014 9:20 PM
chevyguy1523
June 27th, 2012 6:59 PM
Mille Racer 69
May 19th, 2012 7:27 PM
Rknow82
September 17th, 2010 12:13 AM
