Vendor that sells t-case gasket set
I have a 95 K1500 that has an NP241C transfer case. The transfer case works fine with no noise, but it has a small leak. I have searched but cannot find a vendor that sells only a gasket set. Finding a set with bearings is not hard, but I don't need bearings. Does anyone have a suggestion as to who might?
Thanks,
Brad
Thanks,
Brad
Thank You Zuk-man. It is actually leaking where the output housing connects to the main transfer case. I will replace the rear seal while I have it off though. That leads me in the right direction. I will go by there tomorrow at lunch. Then, soon as my AMSoil Severe Gear oil gets here, I'll be in business.
Thanks,
PS: are you ALWAYS on here?
Thanks,
I never met a Fel-Pro Catalogue I didn't like, but I've met quite a few lazy counter parts guys who didn't want to be bothered to look it up IN the cat...
Worst come to worst, there's a lot of good RTV sealers which you can use as a gasket substitute.
dh1
June 16th, 2010 2:16 PM
