Last edit by: IB Advertising
Browse all: Wheels and Tires
- Chevrolet Silverado GMT800, GMT900, K2XX Why is Truck Vibrating
Guide to diagnose trouble and recommended solutions.
Vibration Issues
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> pearl,
Customer Service should have given you the number when you contacted them or they contacted you.
If you would prefer, PM me your name and address and I can look it up that way.
Louis
GM Customer Service
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> pearl,Customer Service should have given you the number when you contacted them or they contacted you.
Louis
GM Customer Service
I went to two other dealerships and two big tire chain stores and had the service managers drive this truck . They all said the same thing ,Not only is it not normal but it could be dangerous and needs to be checked as soon as possible. GM said this is a normal vibration for a 3500 dually and nothing can be done. So thats where I am at now. GM FIX MY TRUCK OR REPLACE IT!!!!!!!
Jeeps had front end shimmy that was sometimes light but could be bad enough to be called "death wobble". It sounds similar to what you describe, came down to design fault. Weight of wheels/tires and slight road irregularity would start a harmonic shimmy that felt like a vibration that was not constant. Problem was finally traced to excessive flex in the various bushings like the A frames etc. What was happening was helped by truing rotors, balancing tires etc. etc. but did not solve the problem, harder bushings did.
Maybe we should start a pole, so we can see if there is a common denominator. Is it happening to vehicles with 4wd, or Z71, or 20 in wheels,crew cab, 1500, 2500 etc. I don't know enough about these trucks yet, or I would start it. Might help figure it out.
Mine is an 2011 crew cab 2wd 5.3L 6 speed 1500 20" wheels
I have had road force balance, two tire replaces, alignment, balanced driveshaft
My wife says I'm being crazy
Mine is clearly in the rear of the truck and starts at 55
