Voltage Swing
Voltage Swing
Hello everyone, hope all is well with you!
On my 2006 Silverado, I noticed that the voltage will start out at around 14.8 volts, but later the voltage will drop to 12.8 volts over a few minutes. When the voltage drops, it stays there until I turn off the engine and start it back up. At one time, the battery and alternator was changed, but no change in what it does. There is no driving problems or starting issues. The only issue comes about when I use my 1000 watt inverter. Some times the inverter will alarm, then shut off and then back on.
When the voltage drops to 12.8v, is the voltage regulator engaging, or tripping out?
Is there another component that I should look at or replace other than the alternator or battery?
Battery terminals are clean and tight. Ground cable connection seems to okay also?
Looking forward to your advice!
there is a module on the negative cable that monitors the alternator output and battery and will shut off the charging in order to keep from over charging the battery. i have the same issue with my truck and then i discovered that when i took it in for service.
