want my truck to sit higher
dont want to drop 1200 for a lift, only looking to go 3-4 inches, i have a 02 silverado 2500hd. sucks i dont have a solid axl, makes everything more expensive. it there a cheap way or any way i can go up like 4 inchs without a lift kit? spacers maybe? need ideas, thanks
Rough country lift for my truck cost 1200....thats alittle ro much. Atleast for right now. What are these torsion keys? Heard theyll give me up to 2 inches then i can do spacers? Would that give me around 4 inches?
Yup installed myself. Saved 800 bucks....and you can't do spacers only torsion keys. Which you can crank the stock ones and get 2" at max. Lift keys give you more if you need them
only thing is the leveling kit only gives me 2 inchs, is there anything that i can squeez 3 inches outa? thanks for all the replys, also is there anywhere i can get this stuff discounted? you said u got urs from a vendor?
You could do 3" with a levelin kit. But your ball joints, tie rods, and cv's if you're 4wd will need replacing rather quick so it's not recommended. It's either a 2" levelin kit, 4" suspension, or a 3" body lift. Body lift isn't recommended on a HD though since they already show tons of frame stock
