Whats the right Tire pressure
When airing up my tires which pressure is it best to go off of the tire pressure indicated on the trie or on the door panel? I have heard from different friends to use one or the other. I typically dont haul heavy loads and keep my truck on the street for the most part right now. Thanks for any input
Official GM Rep
That would depend on whether or not you have the original tires on the vehicle. If so use the pressure listed on the sticker in the drivers door jam. If they are not original tires then I would suggest you use the manufacturers suggested tire pressure. I hope this helps you.
Jeff Morris, Chevrolet Customer Service
tire pressure for our truck tires can be between 40-80psi.
If the max psi is 80, pump it up to maybe... IDK, it depends on if you haul stuff alot
or have alot of passengers.
here, look at this:
here, look at this:
Seems that most road tires are between 28 to 34 psi, but as Mille Racer 69 posted image shows go by what kind of wear you are getting.... the door placard is just a rule of thumb but your load and temp range are going to have some bearing... in the summer here in Texas where its been 103 every day I have to adj the pressure down a bit to keep it in range but come winter when we get the bitter bitting cold days of the 50's I might have to add a bit-o-air...
thompjs
July 6th, 2015 11:18 AM
tonymacias
2007 - 2013 (GMT900)
August 21st, 2012 9:50 PM
