The whole sets of LED Upgrade Guide| Chevy Silverado 1500 2016-2018
Old Dec 20, 2023 | 10:24 PM
LASFIT's Avatar
Former Sponsor
From: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Default The whole sets of LED Upgrade Guide| Chevy Silverado 1500 2016-2018
Upgrading your Silverado 1500 from HID to LED lights is a joyful thing that will make your truck shine, but buying the wrong bulb size can be frustrating. In fact, the first step in the upgrading process is to choose the correct bulb size. We have listed all the bulb sizes of the halogen lights of Silverado 1500 2016-2018. You can purchase the correct LED bulbs based on the bulb size.
OEM halogen bulb size
Low Beam & High Beam: HID-D5S
Front Turn Signal Light: 7443/7444
Center High Mount Stop Light: T15/921/912
Back Up Light: T15/921/912
Cargo Light: T15/921/912
License Plate Light: T10/168/2825
You can try Lasfit LED bulbs on your Silverado 1500. All are plug and play, easy to replace the stock HID bulbs.
Low Beam & High Beam: Pro-CS-D5S
The Lasfit custom-made D5S led bulbs are specially designed for 2016-2018 Chevy Silverado 1500 with D5S HID bulbs. The plug and play design requires no extra cutting or splicing. Much Brighter Than Halogen. Truly 50W, 5000LM per bulb. Besides, another excellent feature is the in-built turbofan on the dust cover which can rotate to dissipates heat outside. When the LED bulb stops working, the vent will close automatically and prevents water/dust goes into the housing. Currently, the only one of its kind on the market.
NOTE:
1. These D5S LED bulbs fit Chevrolet Silverado 1500 2016-2018 with OEM D5S HID bulbs ONLY. If your OEM lights are LED, please don't buy it.
2. These custom-made D5S LED bulbs do not fit GMC Sierra.
Front Turn Signal Light: T-7443D(switchback)
Each bulb has 32pcs SMD 3030 LED chips (24pcs for amber, 8pcs for white). Builtin anti hyper flash Canbus system, specially designed for turn signals. Light up 6000K xenon white for parking lights or daytime running lights (DRL); 3000K flash amber for turn signal lights. Totally refreshed the tired and dim-looking lights with bright white DRLs and crisp amber turn signals. Intelligent Temperature Control System protects led bulbs against excessive current and overheating and ensures a longer lifespan.
Back Up Light & Center High Mount Stop Light: T-T15(white)/T-T15R(red)
3000LM/set, bright white or brilliant red. CANBUS support for error-free. Built-in intelligent temperature control system. 100% plug-and-play installation can be completed in about 5 minutes on most vehicles. Depending on the position and function, you should choose white for back up lights and red for center high mount stop lights.
Cargo Light: L-T15(white)
1400LM/set, 6000K bright white. Lasfit uses high power 3030 SMD LED chip to produce peak brightness output and built-in Constant Current IC driver to ensures reliability. Equipped with CANBUS system, will not cause "lamp out" errors. Plug and play design.
License Plate Light: L-T10(white)
800LM/set, 6000K pure white. 3 high-power 3030 SMD LED chips, top and one on each side, much brighter than OEM halogen bulbs. Non-polarity design, no need any modification, just for plug and play installation.
Real Review from Lasfit customers
Huge thanks to them for sharing their experience with great pictures!
Case1:
Super bright
So I finally changed out the stock hid lights with the led kit that lasfit sells and I can’t believe I waited so long. The Lasfit kitty is so bright that I almost can’t tell my fog lights are on. With the stock hid lights the fog lights were almost a necessity at night but now all they do is brighten the edges of the road because these led lights way overpower them. Super impressive lights.——R.M.
Case2:
2018 silverado 1500
Fitted them on my silverado that has HID xenon lights and this is such an awesome upgrade!! they fit and work like a charm! Took 5 minutes of installation time, the passenger side headlight took 3 min as i had to undo the airbox but everything is plug and play, I’m 100% satisfied and i love your products they are even better than OEM high country headlights and so are the turn signals, cargo lights and reverse lights. Thank you for such an amazing product!——a.y.
LASFIT
Colorado
Nov 21, 2023 12:45 AM
LASFIT
Sep 5, 2023 9:30 PM
PettMk5
2014 - 2018 (GMT-K2)
Apr 18, 2023 12:18 AM
Ozlhuvuadojo
2007 - 2013 (GMT900)
Oct 11, 2022 4:40 AM
