2009 Chevy Aveo LT Key Won't Turn
I recently bought a 2009 Chevy Aveo LT. When you put in the key the entire way the ignition won't turn. In order to get the key to turn you must pull the key out just very slightly. Is this a safety mechanism on this car or is there something wrong with my ignition? It does the same thing with any key that the dealership gave me.:confused:
I see that you've interacted with your dealership on this issue. Have you had the vehicle in to be diagnosed or serviced? If not I would suggest you do so. They would be able to diagnose the issues the vehicle is having and getting them repaired. I hope that helps you. If you still have questions or run into problems then feel free to contact me.
Jeff Morris, Chevrolet Customer Service |
Originally Posted by Rebeka Saunders
(Post 157248)
hello I'm a locksmith
the Chevy Aveo use the same key as a Daewoo go figure the tip of the key wears out making the key go to far in so the dealer probably just copied you're key take the car to a locksmith it dose not have a chip and show him what it dose he should be able to fix the key |
Originally Posted by Keyman
(Post 160834)
the Chevy Aveo use the same key as a Daewoo go figure |
