Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
2009 Chevy Aveo LT Key Won't Turn
Old Sep 14, 2010 | 7:29 AM
Rebeka Saunders's Avatar
Default 2009 Chevy Aveo LT Key Won't Turn
I recently bought a 2009 Chevy Aveo LT. When you put in the key the entire way the ignition won't turn. In order to get the key to turn you must pull the key out just very slightly. Is this a safety mechanism on this car or is there something wrong with my ignition? It does the same thing with any key that the dealership gave me.
Old Sep 14, 2010 | 10:36 AM
Official GM Rep
I see that you've interacted with your dealership on this issue. Have you had the vehicle in to be diagnosed or serviced? If not I would suggest you do so. They would be able to diagnose the issues the vehicle is having and getting them repaired. I hope that helps you. If you still have questions or run into problems then feel free to contact me.
Jeff Morris, Chevrolet Customer Service
Old Oct 22, 2010 | 4:07 PM
Thymeclock's Avatar
Was the brand car new when you bought it? Are the keys that they gave you the original keys, or are they replacement keys?
Old Oct 23, 2010 | 12:22 AM
Keyman's Avatar
hello I'm a locksmith
the Chevy Aveo use the same key as a Daewoo
go figure
the tip of the key wears out making the key go to far in
so the dealer probably just copied you're key
take the car to a locksmith it dose not have a chip
and show him what it dose he should be able to fix the key
Old Oct 23, 2010 | 12:40 PM
Thymeclock's Avatar
go figure
That's because the Aveo IS a Daewoo, made in Korea. Chevy only provided the design and the Chevy bowties on both ends.
Ulteris
Sonic (Aveo)
Oct 31, 2013 6:10 PM
G T Igofast
Sep 3, 2013 3:46 PM
Mr. Vann
Nov 25, 2009 7:24 PM
otacon28
Mar 11, 2007 1:32 AM
