2015 Sonic 1.8l Automatic - Timing Belt
#21
i recheck the timing, got the cam tool for back of the cams.timing is set right on the money. i guess i will have pull the motor out and return it.no compression in 1 and 4 and some in 2 and 3. i also used some crc in all for cylinders and let it set.still no compression.
#22
Just guessing , but I suggest you have the valve timing 180 degrees off . Pull # 1 plug and using a long ratchet / socket and rotate the engine until # 1 is coming up on compression . Then check the timing marsk .
Wyr
God bless
Wyr
God bless
#24
- Ticking noise coming from the engine. The timing belt is attached by way of a series of pulleys to the engine's crank and cam shaft. Cause is misfires, oil leaking in the front of the engine
Chevrolet Forum News
July 30th, 2013 10:38 AM
