Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
aftermarket A/C installation 07 aveo5 svm
Old May 24th, 2008 | 1:26 PM
arizonarancher's Avatar
Default aftermarket A/C installation 07 aveo5 svm
Hello
With this installation, i must install 3 pins into the ecm F25, F30 and F35 on the K64 (lower)connector, is their a special insertion tool required to ensure proper contact is made to pins?
Thanks
Old May 25th, 2008 | 6:53 AM
shawnvw's Avatar
Banned
Default RE: aftermarket A/C installation 07 aveo5 svm
Usually a pick is sufficient enough to insert most pins. I haven't pinned an Aveo before, but there will be a locking mechanism that keeps the pins from fallingout. you'll need to remove that piece, and carefully insert that new pins without being too rough or you could dislodge a few other pins
soccerman58
Sonic (Aveo)
January 25th, 2012 3:47 PM
Yunus
Sonic (Aveo)
September 25th, 2011 11:36 PM
deyond
Sonic (Aveo)
May 13th, 2011 10:49 PM
xfly
Sonic (Aveo)
December 30th, 2008 1:50 PM
tstecko
Sonic (Aveo)
December 15th, 2008 3:29 PM
Quick Reply: aftermarket A/C installation 07 aveo5 svm
