Sonic (Aveo) The subcompact known globally as the Aveo since 2002 is now the SONIC in North America as of the 2012 model
Chevrolet Sonic
GM Platform: T200, T250, T300
Old Jul 24, 2015, 4:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Thermostat housing
Old Apr 8, 2010 | 12:07 PM
BlackAVEO's Avatar
Default Thermostat housing
I have read many complaints about the thermostat housing on the Aveo. It happened to my wife about 3 weeks ago and her story no different from the rest. She was driving and suddenly she saw a cloud of smoke. She thought it was the car in front but it was the Aveo spraying anti-freeze on a hot engine.
I ordered the thermostat housing which came with the thermostat and gasket. Is there a certain way the thermostat has to be positioned. I don't see an indicator and I can't seem to find a Haynes book on Aveo's. Is there an AIR bleeder valve, Please help
Old Apr 13, 2010 | 8:27 PM
dleebold's Avatar
Default metal housing
http://www.ehow.com/how_6124002_repl...hevy-aveo.html +call auto zone and ask,they will help.
Old Apr 24, 2010 | 5:56 PM
therewolf's Avatar
Check the "help,help" thread in this section...
Old May 29, 2010 | 2:13 PM
wittk129's Avatar
Default Chevy Aveo Thermostat housing
I would like to inform everyone that has problems with there thermostat housing cracking or blowing out!! Auto Zone is now carrying a METAL part called a Water Outlet that replaces the plastic thermostat housing. It is only $37 dollar and works great. And it is two pieces so you are able to replace the thermostat if it goes bad. And my husband said it is alot easier to put on!
Old Aug 16, 2010 | 10:51 PM
aquaaveo's Avatar
Default I am with you wttk
I put the AutoZone metal thermostat on my car. Very happy with it but, they did not have it in stock and took three days to get one in. I did make my old one last, if you have a lot of miles, mine went out at 127K miles, I would see about ordering one and just take the 20 mins and do it as preventative maintenance.
Old Apr 14, 2015 | 1:23 PM
jrosepol's Avatar
Default thermostat housing
Where is the thermostat located on the 2011 model. I know previous model it's on the passenger side of the block facing the radiator.
Old Aug 17, 2015 | 4:34 PM
Yas Tsubaki's Avatar
Thermostat housing is problem but on coolant sensor housing plastic that crack my car coolant leak out my 2010 aveo LT this car suck bad material (use aluminum Chevy )
scottfarkus
Apr 25, 2015 8:18 AM
aveodrivers
Sonic (Aveo)
Mar 8, 2014 11:13 AM
SilverK20A3
Nov 18, 2012 12:06 PM
hunterjo
Jan 1, 2012 8:23 PM
atikovi
Jun 12, 2011 9:23 PM
