South AR, LA, MS, KY, TN, AL, GA, FL, NC, SC, WV, VA, DE, DC, MD
Engine Not Starting
Old Aug 24, 2020 | 2:06 PM
Iron Knight's Avatar
Default Engine Not Starting
I have a 2007 Avalanche that has started having an intermittent non-start issue. with key in ACC position, accessories come on. when turned to run position, acc's go off, no engine noise and the door locks cycle on and off as long s I hold the key in run position. It does eventually start, and the clock reverts to 1200, A/C is on etc. Assume those are the factory presets. The battery is about 2 years old.
Any ideas?
Old Aug 24, 2020 | 2:19 PM
kevinkpk's Avatar
Any ideas?
I'd suspect battery, have it tested. If that is ok, i'd suspect body control module.
Victor Vargas
Jun 24, 2018 9:28 PM
csmith731
Aug 29, 2017 9:40 AM
tapout95
May 30, 2015 1:16 PM
BACKinBLACK
Jul 19, 2014 8:13 AM
