03 Tahoe
upgrade rotors and new pads, stock calipers? what are my options? i don't want to spend over 1K. i found some Brembo replacement rotors and i'd like to paint my stock calipers. has anyone on here replaced the stock rotors without going to 14" rotors? any info is appreciated.
you can paint your stock calipers with some hight heat paint. as for the rotors and pads you should be able to upgrade for a few hundred bucks. i cant see any probs. with geting stock size rotors of a beter quatity.check some of the aftermarket web sites and see what they have to ofer.
i forgot, just ebcause your rotors might look rust, they're not bad, it's not just rust. It's actually brake material so if you mesure them they'll measure thicker than new. You can machine those without any probs
