05 Tahoe Transfer Case Problem
Old December 10th, 2013 | 9:08 PM
99fxst99's Avatar
Default 05 Tahoe Transfer Case Problem
While driving on the interstate it went into "neutral" and coasted to a stop. Made a whirring noise when attempting to move fwd and rev. Put it in 4AUTO and drove it away just fine. Then 2HI worked again. When I got home I shifted from 2HI to 4AUTO, no problem, back to 2HI and nothing. 4AUTO again worked fine, but there was a slamming noise when it engaged, sitting still, trans in "N".
I am thinking actuator motor or connection. Thoughts?
Old December 11th, 2013 | 6:38 PM
99fxst99's Avatar
Does decoder sensor ring a bell with anyone?
Old December 12th, 2013 | 4:30 PM
flainn's Avatar
I just had similar problems with my 04 Hoe. It would start up in a random mode each time. Most of the time Auto 4wd, but sometimes 4 Hi or even neutral.
Dealer ended up replacing the transfer case control module; didn't fix it. Then the dealer replaced the transfer case encoder motor and the 4x4 selector switch and that cured the problem.
It was probably just the switch. I told the dealer I thought it was, based on everything I'd read on the Internet, but all they care about is what codes the truck's computer says, then they replace those parts. I'm just glad I didn't pay for it (CarMax warranty).
Good luck. The selector switch is only about $50 from Rock Auto.
Old December 12th, 2013 | 10:13 PM
99fxst99's Avatar
It was the encoder motor.
Truss101
September 9th, 2014 11:40 AM
BS2013
June 22nd, 2013 10:43 AM
marine_man
September 16th, 2011 12:05 PM
tlaura21
May 30th, 2011 7:09 PM
chevythunder25
March 18th, 2009 7:33 PM
