07 chevy tahoe
Old May 1, 2013 | 4:42 PM
marty73's Avatar
Default 07 chevy tahoe
noticed that when you step on the gas going uphill it feel like its chocking, then the stabilitrak & engine light start blinking, even heard a popping noise, not sure if it was a misfire...what could possibly be wrong????
Old May 1, 2013 | 10:37 PM
Welcome to the forum...
I would have the compression checked...just a guess but you could have a valve issue...
does your Tahoe have the Active Fuel management ? ( goes into V4 mode)
Old May 3, 2013 | 1:35 PM
marty73's Avatar
Not sure if it has a v4 mode??? how would i find that out?? I should start from the beginning:
Over the last year I started noticing that the engine oil was burning up faster than the normal. way before the 3000 miles or 3 months, usually after the 2 month mark I had to add oil. within the last 6 months the engine light started coming. It would stay on for sort periods then turn off. I had a friend who is a mechanic check it when the light was on and it was reading had something to do with the throttle body pedal senor?? not too sure. Now the light does not come on but now the car struggles to go uphill and at times both stabilitrak & engine light come on, but not always. Once I pickup speed it no problem, its just when I am at a stop step on the gas to start going uphill and it feels like its checking then I here a pop that comes from the engine...Hope you can help...
Old May 3, 2013 | 2:57 PM
SWHouston's Avatar
Not sure about the Codes, but a cracked Distributor Cap can cause symptoms somewhat like you describe. That's be a simple DIY check.
Old May 3, 2013 | 9:00 PM
15 Year Member
07s and up have AFM (V4/V8) and coil over plug ie, no distributor.
Old May 3, 2013 | 11:48 PM
SWHouston's Avatar
Dang, it's hard to remember stuff like that, when you don't do it every day.
Old May 5, 2013 | 8:03 AM
marty73 you may also want to check the fuel pressure...
its possible you could also have an issue with the throttle position sensor or a throttle body issue...
It could be a number of things, but I'd check the compression and the fuel pressure...
collacor
May 7, 2014 10:01 PM
