07 Suburban LTZ Auto Rear Door Problem
It may be worn struts. The liftgate has an obstruction sensor that reverses the door if it encounters an obstruction. The extra weight of the door can fool the sensor into thinking it is an obstruction. When the door starts to open use your hand to assist it to remove the extra weight and see if it continues to open. Also if the struts are worn the door can drop a few inches from the full up position and then close slowly. If it is not the struts it may be a bad sensor.
