07 Suburban a Qt low 3000mi after oil change
Old April 23rd, 2010, 7:51 AM
Erockhandyman's Avatar
Default 07 Suburban a Qt low 3000mi after oil change
07 4x4 Suburban with 54000mi
It's not leaking and theres no smoke out the tail pipe.
Where is it going?
Old April 23rd, 2010, 8:39 AM
SabrToothSqrl's Avatar
Default well
engine got hungry?
was it filled properly?
Old April 23rd, 2010, 8:50 AM
It was filled properly I did the oil changes. I've noticed it the last couple oil changes. before I get to the 3000mi mark my oil low light comes on. seems like it is slowing getting worse.
Old April 23rd, 2010, 9:10 AM
LARIDERS's Avatar
I would try a diifferent oil. see if that helps.
Old April 23rd, 2010, 8:51 PM
When you fill, do you let it settle before checking?
How many qts are you putting in? Changing filter?
It's not unheard of that the dipstick itself is not accurate.
Old April 23rd, 2010, 9:26 PM
cam3439's Avatar
+1 on what everyone else is saying here, but have you considered an oil catch can? I'm going to buy one pretty soon here. I know of a guy with an '07 Tahoe that saw a teaspoon worth of oil in the catch can after only about 100-125 miles. He had the flex-fuel, AFM 5.3L engine too. I know that the LS based engines have this problem (mainly the LS1, LS6, etc.), but I'm not too sure about the 5.3L engine (especially the newer ones).
Old April 24th, 2010, 3:58 PM
nauticstar87's Avatar
My 6.0 was doing that. Seemed to stop after i switched to Pennzoil Full Synthetic.
Old April 25th, 2010, 5:43 PM
That's a lot of blow-by. I'm guessing ring seating problem.
Old April 25th, 2010, 8:14 PM
cam3439's Avatar
What ring are you talking about? He attached it inline with the pcv hose off of the valve cover. He didn't notice any leaks around the engine or any burning, but when he put this on he did start to catch quite a bit of oil in it.
Old April 25th, 2010, 11:46 PM
The piston rings. The only way you'll get oil thru the PCV line is if you have a lot of blow-by or no windage tray and the crank is whipping the oil into the air.
Quick Reply: 07 Suburban a Qt low 3000mi after oil change
