'07 Suburban radio issues
Sorry if this has been asked, but I searched around and couldn't find anyone having the exact same issue as I have….. it seems that everyone else has all or none while mine is some or all…
What I mean by this is, when the radio is on, the tweeters on the front dash and the tweeters in the far rear are always on and working no matter what, while all the rest of the speakers in the vehicle come and go as they please.. The majority of the time when the door speakers come on, they all come on together. occasionally the drivers side door speaker will cut off while the rest are on. I would say that we are listening to tweeters only 90% of the time and have the entire system playing 10% of the time. can anyone point me in the direction of what might be causing this???? I considered replacing the head unit but I wanted to check and see if this has happened and been resolved by anyone before doing this.
Thanks in advance for any help!
Welcome to the forum
I would start with reseating the connections at the back of the radio and at the amp if you have one... what system do you have Bose, non Bose...
If I recall the amp is located under the center console with the Bose system.
You likely have a bad connection somewhere....
I'd pull the head unit and disconnect and reconnect the harnesses, I am not sure if the non Bose systems have an amp but you can pull the center console and check...
I replaced all four of my door speakers. 3 are working now.
The door panels do not reseat properly. One rear tweeter is out. I'll replace that next.
Will never buy another GM vehicle. I have had 3 Suburbans and they all have these annoying problems that just can't be fixed.
Never had any problems with the sound systems either. I guess I'm just lucky. Then again, out of 12 vehicles I've owned, I've never owned a lemon.
And as the saying goes, "the only common denominator in all of your bad relationships is you."
The upper corner toward the rear of the vehicle will not stay engaged. That is on all four doors. One of my neighbors is car mechanic and can't figure it out either.
There are a bunch of threads about the speakers mysteriously working then suddenly not. The general theme is just start replacing everything until it works again.
For the initial poster in this thread. Replace speakers and see if that fixes it.
I have this same issue I recently replaced all door speakers the back door speakers work now. the front door speakers however come on for about 2 minuets and shut off is this a amp issue or radio issue factory radio and amp.
William J Dorn
April 16th, 2013 9:19 PM
jrsavoie
July 4th, 2011 6:18 PM
CMills
July 21st, 2010 7:16 PM
adamant
February 15th, 2009 8:49 AM
