07 Tahoe Bulbs
Hi. I am looking for some technical specifications on the bulbs in my 07 Tahoe LTZ. What bulbs does it have for the low beams, high beams, fog lamps, marker lamps, turn signals, brake lamps, and reverse lights? I would like to replace these with aftermarket bulbs and do not want to go HID. Any help would be very appreciated!
RE: 07 Tahoe Bulbs
Hey Scott,
On the front platic cover to your headlight it says the size of the bulb in little raised letters, H11 - Low Beam and HB3 for the bulb next to it. Not sure on the others though, Hope this helps, Jay |
RE: 07 Tahoe Bulbs
Hi. So the low beams lamps are H11 and the high beams lamps are HB3?
RE: 07 Tahoe Bulbs
Low Beams = H11
High Beams = HB3 (9005) Daytime running lights/parking lights = 3157 Fog Lamp = 880 ORIGINAL: scott_mckinney Hi. So the low beams lamps are H11 and the high beams lamps are HB3? |
RE: 07 Tahoe Bulbs
Hi. Are these 3157 bulbs amber display or white display then?
RE: 07 Tahoe Bulbs
Also, is there a difference between HB3 and 9005? I see both in catalogs.
RE: 07 Tahoe Bulbs
3157 are white, but a lot of people are installing ambers. These are the lights that stay on all the time.
9005 and HB3 are the same. You may as well order the HB3 P/N from wherver you are looking. Look in the manual also, some of the bulbs are listed in there (rears) |
