07 Tahoe- Code B0163
Not able to retieve any info on the Tech 2 for this code. Hardly any info available. Can anyone PLEASE help?
Thanks! |
Welcome to the forum.
According to the factory service manual, it is the psgr cmpt temp sensor 1 circuit and is set by the HVAC module. Hope this helps. |
I couldn't find the B163 but found these and they are similar in description as 73sharks, they may help narrow the troubleshooting...
DTC B0159 Outside Air Temperature Sensor Circuit Range/Performance DTC B0164 Passenger Compartment Temperature Sensor #1 (Single Sensor or LH) Circuit Range/Performance |
The numbers below refer to the step numbers on the diagnostic table.
</TH><TH vAlign=bottom align=middle>Action </TH><TH vAlign=bottom align=middle>Value(s) </TH><TH align=middle>Yes </TH><TH align=middle>No </TH></TR><TR><TD vAlign=bottom align=left colSpan=5>Schematic Reference: HVAC Schematics Connector End View Reference: HVAC Connector End Views Sensor Resistance Table: Sensor Resistance Table </TD></TR><TR><TD vAlign=center align=middle>1 </TD><TD vAlign=top align=left>Did you perform the Diagnostic System Check - Vehicle? </TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 2 </TD><TD vAlign=bottom align=left>Go to Diagnostic System Check - Vehicle </TD></TR><TR><TD vAlign=center align=middle>2 </TD><TD vAlign=top align=left>
</TD><TD vAlign=center align=middle>5-250 Counts </TD><TD vAlign=bottom align=left>Go to Testing for Intermittent Conditions and Poor Connections </TD><TD vAlign=bottom align=middle>Go to Step 3 </TD></TR><TR><TD vAlign=center align=middle>3 </TD><TD vAlign=top align=left>
</TD><TD vAlign=center align=middle>250 Counts </TD><TD vAlign=bottom align=middle>Go to Step 4 </TD><TD vAlign=bottom align=middle>Go to Step 5 </TD></TR><TR><TD vAlign=center align=middle>4 </TD><TD vAlign=top align=left>
</TD><TD vAlign=center align=middle>5 Counts </TD><TD vAlign=bottom align=middle>Go to Step 8 </TD><TD vAlign=bottom align=middle>Go to Step 6 </TD></TR><TR><TD vAlign=center align=middle>5 </TD><TD vAlign=top align=left>Test the appropriate signal circuit of the air temperature sensor for a short to ground. Refer to Circuit Testing and Wiring Repairs . Did you find and correct the condition? </TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 12 </TD><TD vAlign=bottom align=middle>Go to Step 9 </TD></TR><TR><TD vAlign=center align=middle>6 </TD><TD vAlign=top align=left>Test the signal circuit of the appropriate air temperature sensor for a short to voltage, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs . Did you find and correct the condition? </TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 12 </TD><TD vAlign=bottom align=middle>Go to Step 7 </TD></TR><TR><TD vAlign=center align=middle>7 </TD><TD vAlign=top align=left>Test the low reference circuit of the appropriate air temperature sensor for a high resistance or an open. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs . Did you find and correct the condition? </TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 12 </TD><TD vAlign=bottom align=middle>Go to Step 9 </TD></TR><TR><TD vAlign=center align=middle>8 </TD><TD vAlign=top align=left>Inspect for poor connections at the harness connector of the appropriate air temperature sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs . Did you find and correct the condition? </TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 12 </TD><TD vAlign=bottom align=middle>Go to Step 10 </TD></TR><TR><TD vAlign=center align=middle>9 </TD><TD vAlign=top align=left>Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs . Did you find and correct the condition? </TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 12 </TD><TD vAlign=bottom align=middle>Go to Step 11 </TD></TR><TR><TD vAlign=center align=middle>10 </TD><TD vAlign=top align=left>Replace the air temperature sensor. Refer to the appropriate replacement procedure: <TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Air Temperature Sensor Replacement - Upper Auxiliary </TD></TR></TBODY></TABLE> Did you complete the replacement?<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Air Temperature Sensor Replacement - Lower Auxiliary </TD></TR></TBODY></TABLE> <TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Air Temperature Sensor Replacement - Lower Left Side </TD></TR></TBODY></TABLE> <TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Air Temperature Sensor Replacement - Lower Right Side </TD></TR></TBODY></TABLE> <TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Ambient Air Temperature Sensor Replacement </TD></TR></TBODY></TABLE> <TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Inside Air Temperature Sensor Replacement </TD></TR></TBODY></TABLE> <TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Auxiliary Inside Air Temperature Sensor Assembly Replacement </TD></TR></TBODY></TABLE> </TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 12 </TD><TD vAlign=center align=middle>-- </TD></TR><TR><TD vAlign=center align=middle>11 </TD><TD vAlign=top align=left>Replace the HVAC control module. Refer to Control Module References for replacement, setup, and programming. Did you complete the replacement? </TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 12 </TD><TD vAlign=center align=middle>-- </TD></TR><TR><TD vAlign=center align=middle>12 </TD><TD vAlign=top align=left>
</TD><TD vAlign=center align=middle>-- </TD><TD vAlign=bottom align=middle>Go to Step 2 </TD><TD vAlign=bottom align=middle>System OK </TD></TR></TBODY></TABLE> |
it can get a little complicated but here you go.
