07 Tahoe- Code B0163
Old Feb 8, 2010 | 2:14 PM
bridgemill's Avatar
Default 07 Tahoe- Code B0163
Not able to retieve any info on the Tech 2 for this code. Hardly any info available. Can anyone PLEASE help?
Thanks!
Old Feb 9, 2010 | 2:31 PM
Welcome to the forum.
According to the factory service manual, it is the psgr cmpt temp sensor 1 circuit and is set by the HVAC module. Hope this helps.
Old Feb 9, 2010 | 2:52 PM
I couldn't find the B163 but found these and they are similar in description as 73sharks, they may help narrow the troubleshooting...
DTC B0159 Outside Air Temperature Sensor Circuit Range/Performance
DTC B0164 Passenger Compartment Temperature Sensor #1 (Single Sensor or LH) Circuit Range/Performance
Old Feb 11, 2010 | 9:30 AM
gmpartsguy's Avatar
The numbers below refer to the step numbers on the diagnostic table.
  1. [*]
<TABLE width="95%" border=1><TBODY><TR><TH vAlign=bottom align=middle>Step
</TH><TH vAlign=bottom align=middle>Action
</TH><TH vAlign=bottom align=middle>Value(s)
</TH><TH align=middle>Yes
</TH><TH align=middle>No
</TH></TR><TR><TD vAlign=bottom align=left colSpan=5>Schematic Reference: HVAC Schematics
Connector End View Reference: HVAC Connector End Views
Sensor Resistance Table: Sensor Resistance Table
</TD></TR><TR><TD vAlign=center align=middle>1
</TD><TD vAlign=top align=left>Did you perform the Diagnostic System Check - Vehicle?
</TD><TD vAlign=center align=middle>--
</TD><TD vAlign=bottom align=middle>Go to Step 2
</TD><TD vAlign=bottom align=left>Go to Diagnostic System Check - Vehicle
</TD></TR><TR><TD vAlign=center align=middle>2
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, observe the appropriate Duct Actual parameter in the Heating and Air Conditioning data list.
Does the scan tool indicate that the Duct Actual parameter is within the specified range?
</TD><TD vAlign=center align=middle>5-250 Counts
</TD><TD vAlign=bottom align=left>Go to Testing for Intermittent Conditions and Poor Connections
</TD><TD vAlign=bottom align=middle>Go to Step 3
</TD></TR><TR><TD vAlign=center align=middle>3
  1. Turn OFF the ignition.
  2. Disconnect the appropriate air temperature sensor.
  3. Turn ON the ignition, with the engine OFF.
  4. With a scan tool, observe the appropriate Duct Actual data parameter.
Does the scan tool indicate that the Duct Actual data parameter is greater than the specified value?
</TD><TD vAlign=center align=middle>250 Counts
</TD><TD vAlign=bottom align=middle>Go to Step 4
</TD><TD vAlign=bottom align=middle>Go to Step 5
</TD></TR><TR><TD vAlign=center align=middle>4
  2. Connect a 3-amp fused jumper wire between the signal circuit of the air temperature sensor and the low reference circuit of the air temperature sensor.
Does the scan tool indicate that the Duct Actual data parameter is less than the specified value?
</TD><TD vAlign=center align=middle>5 Counts
</TD><TD vAlign=bottom align=middle>Go to Step 8
</TD><TD vAlign=bottom align=middle>Go to Step 6
</TD></TR><TR><TD vAlign=center align=middle>5
</TD><TD vAlign=top align=left>Test the appropriate signal circuit of the air temperature sensor for a short to ground. Refer to Circuit Testing and Wiring Repairs .
Did you find and correct the condition?
</TD><TD vAlign=bottom align=middle>Go to Step 12
</TD><TD vAlign=bottom align=middle>Go to Step 9
</TD></TR><TR><TD vAlign=center align=middle>6
</TD><TD vAlign=top align=left>Test the signal circuit of the appropriate air temperature sensor for a short to voltage, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs .
</TD><TD vAlign=bottom align=middle>Go to Step 7
</TD></TR><TR><TD vAlign=center align=middle>7
</TD><TD vAlign=top align=left>Test the low reference circuit of the appropriate air temperature sensor for a high resistance or an open. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
</TD></TR><TR><TD vAlign=center align=middle>8
</TD><TD vAlign=top align=left>Inspect for poor connections at the harness connector of the appropriate air temperature sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
</TD><TD vAlign=bottom align=middle>Go to Step 10
</TD></TR><TR><TD vAlign=center align=middle>9
</TD><TD vAlign=top align=left>Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
</TD><TD vAlign=bottom align=middle>Go to Step 11
</TD></TR><TR><TD vAlign=center align=middle>10
</TD><TD vAlign=top align=left>Replace the air temperature sensor. Refer to the appropriate replacement procedure:
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Air Temperature Sensor Replacement - Upper Auxiliary </TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Air Temperature Sensor Replacement - Lower Auxiliary </TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Air Temperature Sensor Replacement - Lower Left Side </TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Air Temperature Sensor Replacement - Lower Right Side </TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Ambient Air Temperature Sensor Replacement </TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Inside Air Temperature Sensor Replacement </TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD vAlign=top> • </TD><TD vAlign=top>Auxiliary Inside Air Temperature Sensor Assembly Replacement </TD></TR></TBODY></TABLE>
Did you complete the replacement?
</TD></TR><TR><TD vAlign=center align=middle>11
</TD><TD vAlign=top align=left>Replace the HVAC control module. Refer to Control Module References for replacement, setup, and programming.
</TD></TR><TR><TD vAlign=center align=middle>12
  1. Use the scan tool in order to clear the DTCs.
  2. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
</TD><TD vAlign=bottom align=middle>System OK
Old Feb 11, 2010 | 9:31 AM
gmpartsguy's Avatar
it can get a little complicated but here you go.
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
Cleaner
Apr 8, 2009 10:32 AM
kjr
Dec 12, 2008 11:02 AM
gr8fulnugz
Dec 15, 2007 9:57 AM
