09 Suburban purge valve fails every few months
My CEL started coming on last year and when I got it out to the auto shop, they told me the purge valve was bad and they replaced it. That took care of the CEL for about 3 months. Light came back on, back out to the shop, the purge valve had failed again and they replaced it free of charge under warranty. Rinse and repeat a few months later. So today it's in the shop for the same thing, they say it's the same problem and are again going to replace the part under warranty.
Have you guys seen anything like this before? I mean I've only paid once for the repair but at the same time it seems like there might be something else going on? I'm not super knowledgeable here though, and don't know if there's something upstream or downstream that could be causing the purge valve to fail?
Thanks -Michael
Thanks -Michael
There’s two. The one I’m talking about is the EVAP Canister Purge Valve, a charcoal based canister that controls the vapors. This one is located by the gas tank. If you over fill the tank it puts gas into this canister and ruins it. The other one is located on top of the engine. So, which one is going bad?
-one is the purge solenoid located near the throttle body..this is opened to allow evap vapour to be drawn into the engine...hence purge
-the second solenoid is located on the cannister...its normally open and allows fresh air to enter the evap system..hence vent. this solenoid closes to seal the system for leak testing.
Rednucleus (May 1st, 2020)
