1995 Suburban 5.7 TBI rough idle nightmare - help please
#12
Annoyingly can't see it being fuel pump, it also runs on (lpg/liquid petroleum gas) and has the same misfire at idle when running on both fuels despite being a different fuel system/pump.
it has to be sensor/vacuum/electrical connection issue
#14
Can you go through the OP’s list and confirm you covered off on what he did? He didn’t the ignition module beneath the distributor cap. Instead of throwing parts at it you might have the garage take a look.
#15
Try your manifold pressure sensor. I was on a cross-country trip to CA desert a few months ago when this happened...very rough starting, would barely idle, but ran just fine on the road. My MAP (?) sensor went out...replaced it and the truck was back to normal.
