1997 tahoe transfer case/trans removal
I'm new to this site and this is the first and only tahoe i've worked on, hopefully you guys can help me out? I'm taking the trans out to get it rebuilt and i'm needing to know if the trans fluid lines need to be taken loose from the trans or cooler, I'm doing this on the ground so any tips would go a long way. Thanks
Welcome to the forum. I'm guessing if you're going to get the tranny very far from the truck, then you'll need to disconnect the cooler lines from it. Also electrical connections and shifter linkage.
Twill08
January 2nd, 2010 2:15 PM
stunna65305
July 12th, 2007 8:42 PM
