1999 Suburban parking/courtesy lights not working
i have checked and swapped the #9 fuse and they still don't work. Any help is greatly appreciated.
You'll need to be more systematic than that. Check the voltage on both sides of the fuse with a multimeter. That should give you the direction you need to go, either upstream toward the lighting fuse or downstream toward the headlamp & panel dimmer switch. Check the courtesy fuse likewise.
