1999 tahoe misfire po305
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
was the enitre injector changed or just the poppet valve at the end?the electrical part on the injector is in main body of the spider assy that could be sticking or dead if its the old style spider assy i would ditch it for the upgraded one worked great on my burb if you do your own work you can get the assy off amazon for about $215
Sean
97 4x4 burb
Sean
97 4x4 burb
you could have the signal to injecters tested,you could buy the test light at most autoparts store, did they test the fuel pressure if the regulator leaks i think it drips into #5 intake runner that could be a possibility
Yes the fuel pressure was checked and is good, and has a good signal to the injectors during normal driving only misfires a highway speeds. Im changing the ecu tomorrow w/ another and having it flashed for this car We'll see ??? what happens
