2000 suburban wont communicate with scanner unless I use a jumper wire at the splice
Old July 27th, 2019, 5:01 PM
2000burbanboy's Avatar
Default 2000 suburban wont communicate with scanner unless I use a jumper wire at the splice
These are the codes it has
I have a 2000 suburban scanner wont communicate to pull codes or data unless I use a jumper wire at the splice pack g205 under the steering column... I'll try to post a video of what my truck is doing... with the codes its throwing it shouldn't be able to start and run but it does run n fine just the dash looks like an airplane with all the lights on... I changed ignition switch, tried the cluster, then when I disconnected the bcm the truck started and stayed running with no issues, and then I unplugged the 3 wires on top the ignition lock cylinder it still ran with no issues... I checked all fuses, all good. Checked all grounds all good..THANK YOU FOR YOUR HELP AND ADVICE IN ADVANCED.
Old July 28th, 2019, 8:11 AM
Cusser's Avatar
Check for a burned-out fuse labeled "Cigar". Happened on my 2004 Suburban.
Old July 28th, 2019, 10:10 AM
All fuses are good.. I'm getting power at the obd2 plug and it powers my scanner.. just wont communicate with any modules on it unless I use a jumper wire at the g205 ground splice pack
Old July 28th, 2019, 11:39 AM
to clarify: how many are offline.... are all modules off line without the jumper and all are online with the jumper?
Old July 28th, 2019, 6:20 PM
With the purple wire jumped to the dark green im able to communicate with the ecm and bcm only
Old July 28th, 2019, 6:22 PM
All are offline until I use the jumper wire.. I checked the grounds in the frame by the abs module, the ground behind the passenger side head.. all are ok
Old July 28th, 2019, 11:35 PM
if the class 2 data line wire to the dlc is open you will not be able to connect to the scan tool. the truck will have at least 6 modules...most module power and grd sources are not shared. since you have lost all modules and the class 2 data lines are wired in series at splice 205....and you jumped a open and they now communicate
disconnect the splice from all modules and check continuity on the dlc pin 2 to each output at the splice.
Old July 29th, 2019, 6:34 AM
Ok I'll check that today. Thanks
Old July 30th, 2019, 9:35 AM
I'm only getting continuity at pin a which is the purple pin. The others are dead..
Old July 30th, 2019, 9:38 AM
Just noticed today that with key off I can get data from the bcm
