2002 Suburban wipers work on high only
Hello everyone,
I have an 02 Suburban, and the wipers work when the switch is in the high position only. They do not move anywhere else, and they shut off wherever they want. Anyone have any idea what the solution to this problem is?
Thanks!
Dave
Thanks!
Dave
it sounds like your switch is going. its like an auto tranny one gear might go but the rest are gona go soon. i think its the contacts that are going
Thanks. I have the ESI discs so I installed them and did the diagnostics, and it turns out that the control board that is on top of the wiper motor has a broken diode. I'm trying to get the diode at Radio Shack today as the part doesn't seem to be available locally, and I'd rather spend 15 cents than 40 bucks. rockauto.com does have the part. If you have this problem, chances are this is what the cure is. I think the diode wasn't soldered in properly, as one end of it was out and it was broken in half, the loose half was stuck in the grease.
wjm40a
Uplander
10
September 5th, 2018 9:35 AM
rjatherton
August 6th, 2012 10:17 AM
