2003 Suburban Extended Crank Issue - help?
Old May 13th, 2012 | 10:23 AM
gslim's Avatar
Unhappy 2003 Suburban Extended Crank Issue - help?
Hello,
My 2003 Suburban has extended crank issue after truck as been off for 2-3 hours.
However, if I turn key to ON position and wait 1-2 seconds (after listening to the noise in the back area) the truck starts fine.
If I do NOT turn to ON position and wait, I experience the extended crank and the truck won't start. On the 2nd attempt, the truck will start fine.
I've recently had fuel induction cleaning and replaced fuel filter. I also replaced the spark plugs and wires.
Please help? Thanks!!
Old May 13th, 2012 | 12:38 PM
cleveland63b's Avatar
check fuel pressure and make sure it doesn't bleed off when you turn the key off, by the sounds of it the check valve in the fuel pump assembly is bleeding off
Old May 13th, 2012 | 2:42 PM
gslim's Avatar
OK, I'll take it to a shop to have this checked out
thanks!
Old May 13th, 2012 | 7:28 PM
you can put in an inline check valve to not have to change the fuel pump.
Old May 23rd, 2012 | 8:51 PM
gslim's Avatar
You were right, the problem was the check valve. thanks!
My truck is still under the extended warranty. They're going to replace the fuel pump
Tony773
July 21st, 2015 7:08 AM
calbyd
July 19th, 2015 11:09 PM
RobotRick
March 15th, 2014 11:53 AM
Kari Anton
January 9th, 2013 2:47 PM
rell43
Uplander
June 7th, 2012 10:24 AM
