2004 sub 8.1l volt/idle drop
Hi all, new to the forum so I hope I'm posting in the right place.
Here's my issue, when in any gear, under any load at idle my voltage will drop from 14 to 13 and my RPM's from 700 to 500 and sometimes a little lower. No CEL or codes stored or pending.
Things I've tried:
-Cleaned MAF and intake
-Plugs and wires
-Had the auto parts store test the battery and alternator, both tested good
Soon to try:
-Clean all ground points (if anyone knows where they are located that would be great). It's from the the far north so it has some underbody rust issues.
- intake manifold gasket (does this line up with my issues?)
-smoke test for vacuum leaks
Please let me know if you know what the problem is or any direction I haven't already thought of would be greatly appreciated!
Kind Regards,
Things I've tried:
-Plugs and wires
Soon to try:
Kind Regards,
I sure appreciate your feedback, but this year (2004) they went to a returnless system so it's all in the tank now. Any other ideas?
EGR valve is a thought but without a code not sure I'm willing to just spend the money to replace it. I may just clean it and see what happens. Thanks again
