2005 Suburban HVAC issues
I know this a common issue but everything I have found doesn't match up with what is going on with mine. I have recently bought a 2005 suburban purchased it in the summer and the ac was ice cold so I didn't have any issues until the winter hit and found out that the heat didn't work at all and the vent selector did not work either. Found out that the previous owner had pulled the HTR/HVAC fuse, so I replaced fuse and the heat on the drivers side would work when I put the temp selector in the middle(I have the slide controllers not the digital), passenger side was still ice cold and the rear heat works but cannot change the vents it is on the overhead one and stuck there. Did some more research and found out how to calibrate the system. Did this now the driver side heat works great, I can change to all the vents and the temp selector works as it should(goes hot on hot, cool in the middle and cold on the bottom) passenger side is still ice cold, and still cannot change any vents on the rear. Everything I have seen is that when the blend door actuators fail the fail on hot which would be find through the winter, but this does not seem to be the case since I still have ice cold air on the passenger side. My question is, is there something that I am missing, another fuse possibly, or did the actuator fail, or did the controller in the dash fail? Has anyone else had a similar issue?
I'm trying to cool down, but my 2005 suburban 2500 does not seem to want to blow through the AC coil. Pressures read good, line in engine compartment showing cold, but air still blows hot on both sides. This is a manual control system. followed recalibration several times. I'm stumped
JoJoHD
December 5th, 2022 10:34 PM
