penzfan |
December 21st, 2016 7:29 PM |
Cruise Control Issue
[QUOTE=cleveland63b;312658]No its electronic control, does the indicator come on when you turn on the switch?[/QUOTE
OK. So it's been 1 year since I replaced the fuses, brake light switch and turn signal/wiper/cruise stem on the steering wheel and still no Cruise Control. However, last Sunday I hooked up a U-Haul Trailer to move some stuff across town and the damn green Cruise Control light lit up when I pressed the button and the Cruise worked perfectly. Once I turned the U-Haul back in the Cruise is not working again. I thought maybe the 7-pin adapter used to plug in the 4-pin connector for the trailer lights somehow triggered the Cruise circuit to work. I plugged the adapter back in but the Cruise is not working. Any other ideas would help. At least now I know all the fuses, brake light switch and column stem are in working order.
