2006 Suburban Cruise Control
Old Dec 9, 2015 | 2:05 PM
penzfan's Avatar
Default 2006 Suburban Cruise Control
Does the 06 Suburban Cruise Control work via vacuum lines? I have replaced the fuses and switches and cant get it to work. Thanks
Old Dec 9, 2015 | 8:39 PM
cleveland63b's Avatar
No its electronic control, does the indicator come on when you turn on the switch?
Old Dec 10, 2015 | 2:54 PM
penzfan's Avatar
No. The green dash indicator does not light up when I press the button or slide the switch on.
Old Dec 21, 2016 | 7:29 PM
penzfan's Avatar
Default Cruise Control Issue
[QUOTE=cleveland63b;312658]No its electronic control, does the indicator come on when you turn on the switch?[/QUOTE
OK. So it's been 1 year since I replaced the fuses, brake light switch and turn signal/wiper/cruise stem on the steering wheel and still no Cruise Control. However, last Sunday I hooked up a U-Haul Trailer to move some stuff across town and the damn green Cruise Control light lit up when I pressed the button and the Cruise worked perfectly. Once I turned the U-Haul back in the Cruise is not working again. I thought maybe the 7-pin adapter used to plug in the 4-pin connector for the trailer lights somehow triggered the Cruise circuit to work. I plugged the adapter back in but the Cruise is not working. Any other ideas would help. At least now I know all the fuses, brake light switch and column stem are in working order.
