2007 Chevy Suburban Liftgate Fuse Issue
Hi,
I have a '07 Suburban that has a liftgate that stopped working. I checked the actuator and it seems to work. I tested the switch using a voltmeter and it seems okay (but I'm no electric guru). There doesn't appear to be power going to the actuator so I sought out the fuse which I believe to be position 44 on the panel. I used a test light on both sides of the fuse and there is no power on either side of the fuse. Is this normal? I wouldn't think that the fuse is a switched fuse but rather a "constant" fuse. (meaning that there's power at the fuse constantly) I checked the cannon plug at the actuator and there is only one of the pins that has power but it isn't the pin that runs the actuator.
Any thoughts?
Ray
Any thoughts?
Ray
