2007 Chevy Tahoe ABS, Traction Control and brake light. C0110
Have a 07 Tahoe with the abs, traction control and brake lights on. Stability off message as well. Ran the ABS code and got C0110-00. Checked and cleaned grounds. Checked ABS module connector for power on two pins and ground on two. Checked out. Possibly bad ABS pump?
Did you use a contact cleaner/lubricant in connectors? Not only clean it's connector but follow the ground back to it's chassis connection and clean it also before replacing parts.
Thanks for the reply by the way!
