2007 Tahoe...17 inch vs 20 inch Tires?
#11
RE: 2007 Tahoe...17 inch vs 20 inch Tires?
Unless you're going to put a lift and a set of off-road tires on any Tahoe, I wouldn't consider it a stock "true off-road" vehicle. The approach angle at the front of a stock Tahoe is too narrow and it has too long of a wheel base. Plus it's too wide for most mountainous trails. So you won't be able to take a stock Tahoe on such technical trails that 17" or 20" wheels would matter. However, you are correct with the general statement that more tire is better when off-roading then you can adjust tire pressure as needed.
lrfjeffers
August 17th, 2013 12:16 PM
upsidedown
12
January 27th, 2013 1:19 PM
lcampbell
October 28th, 2012 7:08 PM
chevysilverado2001
December 28th, 2009 6:12 PM
TEAMXTREMEAUTO
June 21st, 2007 10:00 PM
