2007 Tahoe, Wheel help......
Old Nov 9, 2006 | 5:27 PM
deejayrock's Avatar
Default 2007 Tahoe, Wheel help......
Hello all,
I was wondering if some of you wheel guys can help me out with a fitment question for the 2007 Tahoe, here are the wheel specs below, I'm wondering if there will be a fitment issue and what tire I can use with these wheels, I was looking to go with a 305-45-22 tire so I can have more rubber on the rim, but not sure about rubbing.
Wheel info:
22X9.5 BLACK
6x5.5 (6x139.7)
12 MM OFFSET
5.75" BACKSPACING
Thank you for any help you may be able to provide.
Jay
Old Nov 9, 2006 | 6:04 PM
Gapp's Avatar
Default RE: 2007 Tahoe, Wheel help......
If you are not lowered, you won't rub. Check out this site: http://www.1010tires.com/TireSizeCal...?action=submit
Old Nov 9, 2006 | 6:12 PM
deejayrock's Avatar
Yeah, I don't plan on lowering the Tahoe, I'll check out the website though, Thank you.
Old Nov 9, 2006 | 6:18 PM
biglg's Avatar
The offset isnt as close as i would want! The stock offset is +31! Go to this site to check out how much difference the wheels will set on the vehicle.
http://www.1010tires.com/WheelOffsetCalculator.asp
I am sure the wheels and tires will work. There are several that have put on +12 offset wheels with no problems. It is all personal preference! As for the tires, i cant answer that. But I believe 305/40/22 is what I was going to go with if I ended up with 22's.
By the way, backspacing is always in relation to the offset. It is basically another way that offset can be determined! Not a big deal, just letting you know in case you were wondering!
samp215
Feb 24, 2009 10:43 AM
subirs05
Aug 7, 2008 12:44 AM
MCF34
Jan 7, 2008 8:49 PM
MCF34
Dec 18, 2007 6:32 PM
cabin232
Jul 15, 2007 9:57 PM
