2008 chevy tahoe 5.3 flex fuel overheating after new thermostat
Old Feb 1, 2024 | 7:45 PM
Rackle79's Avatar
Default 2008 chevy tahoe 5.3 flex fuel overheating after new thermostat
So replaced the thermostat cuz the heat wasn't working. Truck drove fine until today about 2 weeks after the fix. It's starting to overheat again and intermittent loses heat. Also the coolant is going somewhere. Not sure if there is a leak that I just can't see. Cuz there isn't coolant on the ground. Anyone have any suggestions. Or ideas
Old Feb 2, 2024 | 7:37 AM
Welcome from Florida. Check to see if there is water in the oil. The oil will be milky white if there is water. It could also be a bad head gasket losing coolant into a cylinder and burning it away with the exhaust.
Old Feb 2, 2024 | 8:39 AM
Cusser's Avatar
Occam's Razor suggests that the most like solution is the most obvious one. Which means look at what was the most recent change.
So I suspect a leak due to installation of that new thermostat. Also, it's possible that all the air wasn't bled out of the system when refilling with coolant. Don't overlook bad radiator cap causing loss through the coolant reservoir either.
Investigate: don't guess !!!!
allad
Nov 28, 2021 10:03 AM
ddemier7
Jul 1, 2019 10:08 AM
Prezmil2020
Jan 16, 2010 9:05 AM
JesseC
Aug 24, 2009 8:09 AM
