2011 ltz suburban A/C compressor not engaging
Old April 1st, 2021, 9:14 AM
  #11
connected the signal wire should have voltage with a charge in the system. you need to test with a voltmeter
Old April 9th, 2021, 1:24 PM
  #12
3Js
3Js's Avatar
I believe the 3 pin round connector in the small line near the compressor is the high side pressure transducer switch. I had to replace mine in my 06 Burb.
Have you tried jumping the compressor cycling switch on the accumulator, passenger side firewall.
It is a 2 pin connector. Try jumping the connection with a paper clip and see if the compressor engages.
scumpoozie
August 15th, 2023 9:12 AM
maxstead
March 11th, 2023 4:30 PM
Justin Gibson
August 6th, 2020 9:36 AM
bryters
July 11th, 2012 10:57 AM
XeroVolume
April 24th, 2010 10:48 PM
Quick Reply: 2011 ltz suburban A/C compressor not engaging
