2011 Tahoe-HORRIBLE Vibration at 75-80 mph
I just had all new tires static balanced, both new u-joints in rear drive shaft, and drag link replaced. Any other suggestions for me?
I am a mother of a child with special needs, really want to find the issue and not be stranded on the side of the road or worse.
Can you tell if the shudder is coming from the front or rear? You can also start with some simple things like making sure the wheels are properly mounted and the lug nuts are properly tightened/torqued. If you think it is an issue related to the work you had done you can take it back to the shop that did it, should be under warranty.
did the vibration start after the new tires were installed or was tire replacement a fix for the vibration?
static balancing is a short cut method of tire balancing. At minimum they should be dynamically balanced. In your case they should be roadforce balanced to determine if there is radial tire variation. RVT is a variation in the stiffness of the sidewall of the tire. It can be present on new tires and they can balance perfectly but shake violently. It can only be detected with roadforce balancing.
Is the vibration transmitted through the floor of the vehicle or into the steering wheel?
Not sure what part was replaced. tahoe's do not use drag links...drag links are used in coil and link (solid front axle suspensions). tahoe use parrallelogram or rack and pinion front suspension.
I only road force balance now. Not worth hassle to not. Any place that doesn't is missing the boat.
Does the vibration increase with speed, or only occur at certain speeds? does it occur when braking or just accelerating?
are you able to take other passengers and help isolate the location, perhaps a specific area/tire?
Have you tried moving the tires around to see if it changes the situation?
Guess i'd start with road force balancing. But maybe also have the ball joints checked as well as shocks, tie rod ends, etc. Only time I had a vibration at speed like that was a u-joint in the driveshaft, and replacing it fixed the issue.
It's hard to diagnose that kind of a thing over the internet. I doubt that it would be the U-Joints unless they really screwed something up bad. Probably a tire way out of balance.
