2015+ hoe/burb 4wd low
I am sorry to post if this has been covered but I can’t find any answers searching the internet or this forum. I currently have a 2007 Suburban 1500 and love it but I think it’s time to step into a newer model. I have seen some pics of Burbs’ on dealer sites and some have shown the 4wd knob but I don’t see a 4wd low on it. Were the 2015+ Burbs made with 4wd low? Any info would help because I don’t want to get a newer Suburban to find out that I didn’t get all the options that I would like to have. Thanks!
some don't have 4 low. for me its a feature I never use. I don't go off road so I can't think of many reasons I would need it...pulling someone out of a ditch?
Originally Posted by tech2
(Post 431816)
My old Jeep CJ-5 even had a 2 wheel drive low setting in the transfer case, but it wasn't on the floor shifter knob etching. You punch it in 2-low you'll bust an axle shaft or worse. Was nice for backing out of places without slipping the clutch but that baby was built in the 1970's. Solid front axles and Warn locking hubs. Four speed transmission it would crawl like a crab in granny low and t-c low. |
Originally Posted by Jzobie
(Post 431796)
I live on a hill so steep that USPS won’t deliver mail to my street so while I don’t use 4wd low very often on my ‘07 Burb, I have used it. I have a travel trailer and with the wife the kid and 2 dogs a pickup just doesn’t get the job done. I have loaded 8 people into my suburban countless times as well. The Tahoe doesn’t work because I also use my truck to haul construction material and I can load full boards, plywood, and Sheetrock into the suburban and close the back door all the way. I guess I can get by without the 4wd low but they are definitely making it less of a truck which is what I love about the Suburban. Hell, I wish they still made a 2500 version, that is what I would be getting if they did.
(Post 431826)
propane in rear-axle rigs, I'd hit a steep uphlll drive (not snow/ice) and punch it to the max. No 4x4 just tons of momentum, Always made it to the top of the grade every time. |
Ok so I went onto Chevrolet’s site and used the Build and Price feature to kind of reverse engineer what I am looking for. The Tahoe’s and Suburbans with the max trailering package come with built in trailer brake, 2 speed transfer case giving the truck 4wd low and also Neutral (not that I have ever used that) and 3.42s. I believe it is called max tow for the Yukon and Yukon XL. Knowing this allowed me to search the photos of the CPO trucks and if it has trailer brake to the right of the 4wd selector then it is what I am looking for. Obviously I need this package to tow so it limits the number of Burbs that will work for me but I will get exactly what I need. Hopefully this helps anyone in the future looking for towing as it increases tow capacity from I believe 6,200 lbs to 8,000 lbs.
Thanks!
(Post 431853)
