2015+ Tahoe door trim falling off
Has anyone had issues (and repaired themselves) the black panel door trim near the windows?
2015 Tahoe Door Trim
Is this something that can be repaired with some automotive tape or does it require dealer? I'm out of bumper to bumper warranty
Any special tricks to popping them off?
If you haven't done so already, how about calling a body shop and ask what they would use to fix your issue. But from your photo, there appears to be two holes that would suggest that small screws are use to hold that trim piece on. But then again, those holes could be where protruding trim mounting points insert into. (Just thinking as I am typing along)
When you have a fix, please come back and post up what the solution was so others who may experience a similar issue will know how to have the fix completed.
So far the automotive tape is holding up. I just used about 1 square inch on the metal clip area where the top broke free. If I ever figure out how to remove them w/o breaking them I'll post back.
The correct term for these are "Applique"
Applique, LEFT for 2015 Chevrolet Tahoe|84021603 : GM Parts Direct: Your direct source for Genuine GM Parts
