2016-2020 Chevrolet Tahoe LED Upgrade Bulb Size Guide
Old Jan 9, 2024 | 10:03 PM
LASFIT's Avatar
Former Sponsor
From: 9155 Archibald Ave Ste. C, Rancho Cucamonga, CA 91730
Default 2016-2020 Chevrolet Tahoe LED Upgrade Bulb Size Guide
Frustrated with the complexities of upgrading your Chevrolet Tahoe to LED? Look no further! This comprehensive guide is here to make your life easier. We'll help you navigate through the process of identifying the OEM halogen bulb sizes and finding the right LED replacements. With our detailed bulb size chart, you can rest assured that you'll have the correct LED bulb sizes for a seamless installation. Say goodbye to the headaches and confusion, and say hello to a sleek and modern LED upgrade for your Chevrolet Tahoe.
Low Beam: H11 for Halogen Bulb
Low Beam: D3S for HID Bulb
High Beam: 9005/HB3
Fog Light: 12278/PSX26W
Front Turn Signal Light: 7440/7441
Rear Turn Signal Light: 7440/7441
License Plate Light: T10/168/2825
Back Up Light: T15/921/912
You can try Lasfit LED bulbs on your Chevy Tahoe. All are plug and play, easy to replace the stock halogen bulbs.
Low Beam: LSplus H11 for Halogen Bulb
For low beams, Lasfit recommends the LSplus H11 LED bulb. The LSplus series is known for its powerful brightness. The LSplus H11 LED bulbs are much brighter than Halogen, 90W/set, 9000LM/set, 6000K bright white. The real parameters guarantee a significant increase in brightness!
The high-power operation of LED bulbs also places higher demands on their heat dissipation capabilities. Lasfit's uniquely customized stronger heat dissipation system for the LSplus series plays a role. With dual ball cooling fan design and 42mm heat dissipation system surrounded, The bulb can maintain a stable low temperature during operation. Intelligent IC make sure the LED conversion kits last longer.
Low Beam: LSplus D1 for HID Bulb
100W, 11000LM per set, provides excellent night time driving by taking an amplified flux beam with 6 pieces 80*80 mil chips on each side, which means they have the same beam pattern design as the HID ones. The light will be more focused. Zero "warm-up" time with brilliant pure white lighting, instant-on at full brightness. The LSplus D1 is uniquely customized to replace factory D1S D1R D3S D3R HID bulbs. It is not plug and play. This product includes two adapter wires, you can use that to splice into the factory wires.
Smart efficient cooling system, larger aluminum body, built-in more powerful high-speed cooling fan, and external driver with better heat dissipation, ensure super cooling ability and highly efficient heat dissipation even in a long-time driving. The lifespan is far more than 30000 hours.
High Beam: LSplus 9005
The LSplus series has amazing lumens and can emit astonishing brightness. If you want to experience the safe feeling of nighttime driving as if in daylight, the LSplus series is your best choice. With much more brightness than halogen and a real 9000LM per set at 6000K cool white, the LSplus will greatly increase your visibility.
With LSplus 9005 LED conversion kit, the installation is pretty straight forward. The mounting collar is adjustable for freely rotate. Free to adjust the socket until it shines the perfect beam pattern.
With dual ball cooling fan design and 42mm heat dissipation system surrounded, The bulb can maintain a stable low temperature during operation. Zero risks about the overheat to damage the assembly, and intelligent IC make sure the LED conversion kits last longer.
Fog Light: LCplus PSX26W
LCplus series are designed as small as it can to fit the assembly with bulb hole off the center. LCplus is one of the smallest LED lights on the market, with built-in driver which can perfectly fit most vehicles without installation issues. Plug and Play. Truly 50W/Set, 5000LM/Set. Let you experience brightness far beyond halogen bulbs. 360° Adjustable Beam Pattern.
Not Only The Smallest, But Also More Stable! The led bulb with the all-aviation aluminum body, hydraulic fan and built-in intelligent IC and temperature control system can perfectly solve the problem of light decay and dead lamp caused by the highest temperature of LED car light to ensures it will last longer.
Back Up Light: T-T15(White)
3000LM/set, 6000K bright white. CANBUS support for error-free. Built-in intelligent temperature control system. 100% plug-and-play installation can be completed in about 5 minutes on most vehicles. We recommend using the white color for the back up lights, this will enhance the clarity of illumination when reversing.
Front Turn Signal Light & Rear Turn Signal Light: T-7440A(Amber)
24W/bulb, 2300LM/bulb super bright amber light. T series turn signal light is built-in Canbus resistor system, anti hyper flash, error-free, no error message. Plug and play, no need resistor, no flickering. Totally refresh the tired and dim looking stock lights. Intelligent Temperature Control System protects led bulb against excessive current and overheating and ensures a longer lifespan.
License Plate Light: L-T10(White)
800LM/set, much brighter than OEM halogen bulbs. It's necessary and easy to achieve to add a modern appearance to your truck by replacing stock halogen bulbs with this LED bulbs. No need any modification, just for plug and play installation.
LASFIT
Jan 4, 2024 9:49 PM
LASFIT
Jan 2, 2024 8:33 PM
LASFIT
Colorado
Dec 21, 2023 10:12 PM
LASFIT
Dec 20, 2023 10:24 PM
LASFIT
Colorado
Nov 21, 2023 12:45 AM
