4x4 problem
< => <!-- var SymRealOnLoad; var SymReal; Sym() { window.open = SymWinOpen; if(SymReal != null) SymReal(); } SymOnLoad() { if(SymRealOnLoad != null) SymRealOnLoad(); window.open = SymRealWinOpen; SymReal = window.; window. = Sym; } SymRealOnLoad = window.onload; window.onload = SymOnLoad; //--> </> I have a 2002 Z71 and now when I switch to 4wd, the service 4WD light comes on and I can not switch back to 2wd without turning the Tahoe off. When I start it back up, I can then switch back to 2wd. Can suggests on the problem and possible solutions? |
4x4 problem
Chevrolet has had problems with the four-wheel drive switch. You might try replacing the switch to see if that will fix it. Switch is relativly cheap from the dealer
RE: 4x4 problem
Ive found I have to throw it in nutural and be going like 5-10 mph for it to pop out of 4wd, especially out of low.
