90 Suburban and distributor problems
In the past 2 years I've burned through 4 distributors. We noticed that the problem starts with the rotor and progressively gets worse. This last time I replaced everything in April, and just the other day It wouldn't fire up for me while i was out grocery shopping. Got it home, we go through the simple checks, and since I've had the problem before, we check the distributor. We noticed the rotor was starting to burn through again.
Does anyone know why this happens so frequently?
I'm here for the party
when you replaced the rotor, did you replace the cap along with it or the whole distributor? im familiar with the old HEI's, have a few of the older trucks and two with the tbi units. i personally never had this issue even on my mud truck but thought this issue was kind of a deal with only the HEI not the TBI with a remote coil. as this was the result of arcing between the carbon button and rotor contact due to button wear. but the "burn through" was on the cap side not the rotor, granted you have to replace everything but ive never seen the rotor burn through and only get all arced up
When it was running right, I would just replace the cap and rotor, regular maintenance. But since I've been having this problem, I've been replacing the whole distributor. This last time though, my uncle swapped out rotors and it worked.
