93 suburban C1500 - jerks at slow speeds
Old March 23rd, 2013 | 9:53 AM
Rupesy's Avatar
Default 93 suburban C1500 - jerks at slow speeds
When I am cruising through a parking lot at a very slow idle speed and I gas it just a little, the burbs jerks back and forth almost like a manual transmission when you have left the clutch out too early. I have noticed it does it sometimes when I am on the highway and let off the gas it sometimes jerks a little. Doesn't do it if you pull out normally. Only seems to happen when you are just slightly on the gas. I have put in new injectors and TPS but it existed before that. Cap, distributor, wires plugs are all fairly new.
Old May 25th, 2013 | 9:05 AM
Rupesy's Avatar
I have been reading a lot of posts that this might be related to a faulty EGR valve or solenoid. Has anyone had any success with fixing this problem by replacing one of those two items? I really hate just buying parts to troubleshoot. Is it possible to give it a good cleaning? How would I clean it?
Old June 1st, 2013 | 8:27 PM
Rupesy's Avatar
Update: I disconnected the EGR valve and plugged the vacuum line and problem solved! So now just need to replace the EGR valve.
ebacon
January 5th, 2024 7:44 PM
Cmk112
April 4th, 2013 10:50 PM
1990Chevy_Steve
July 14th, 2012 7:34 PM
95 z71 stroker
April 29th, 2012 10:27 PM
jose
May 6th, 2011 11:19 AM
