96 Sub left blinker,tail light,brake light don't work
The left blinker just clicks quickly, the RIGHT one works normally, the left rear blinker, the LR brake light and BOTH tail lights do not work!!! ...everylight works perfectly in the front-both sides, Only the reverse light works on BOTH REARS. I have tried to chase wires,, I have replaced bulbs, fuses,,,.. I need some help!! ANYTHING will be deeply appreciated
THANKS!!
Steve
THANKS!!
Steve
?? the wires are all sealed(connector too).. and there is no "ground wire" from the tail light assembly, but I took a multitester and checked from the black wire to the frame and there was no resistance -ground checks ok from the wire connector (black) to the frame.
no tail lights - no driver brake light - no driver blinker BOTH reverse lights work.. passenger brake light works..
HELP!!!
HELP!!!
I checked the wires for power at the connector,,, no power to any wire except the reverse light... now I am really confused... could it be in the turn signal switch??..I took most of the dash apart.. no loose connectors, or anything out of the ordinary that I could find/see
deperate for answers.. taking it to a "shop" will be outragous...finding one I trust to tell me the truth....even harder.
RomanGuzi
Oct 2, 2011 11:40 AM
beckya99
Jul 12, 2011 12:29 PM
bigreed91
Feb 19, 2011 11:32 PM
