96 tahoe IFS Axle
Old Jan 7, 2010 | 2:02 PM
tahoe96's Avatar
Default 96 tahoe IFS Axle
Working on front axle, My driver-side stub axle has some up and down movement I am prepared to rebuild the axle completely. Before I tear into the housing I would like to get some info on the axle. On the axle bearing how do you set the pre-load on bearing? Does it take a special socket that locks into the groves on the plate that is holding them in place?
Old Jan 7, 2010 | 7:16 PM
mudmaniac's Avatar
Ride of the Month
May 2009
I have always been able to turn them by hand or with a punch and a little tap.
The way the diff comes apart, the drivers side would be adjusted for depth and then the carrier is reinstalled. Next you reinstall the passenger side of the case and adjust the bearing on that side for pre-load.
Old Jan 8, 2010 | 5:18 AM
tahoe96's Avatar
So would marking the the postion before disaembly and re-install using those marks work?
Old Jan 8, 2010 | 7:02 AM
mudmaniac's Avatar
Ride of the Month
May 2009
That would be my suggestion.
Old Jan 9, 2010 | 9:56 AM
tahoe96's Avatar
OK I disassembled the carrier and found the bearing I suspected to be worn. The drivers side axle bearing. I don't think I am going to replace the pinion bearing as it seemed to not have any slack in the gears. When I am setting the pre-load on the passenger side do I do it similar to wheel bearings (tighten until all slack is gone and then 1/4 or 1/2 turn more) or do i use a inch pound torque wench as you have to do when setting the pre-load on the pinion. Thanks for your comments.
Old Jan 10, 2010 | 5:38 AM
mudmaniac's Avatar
Ride of the Month
May 2009
I would go with your first method, snug it up and a 1/4 turn more.
mudmaniac
Sep 18, 2012 10:17 AM
chevy619
Jun 11, 2012 3:59 PM
zuren
Sep 25, 2011 11:09 PM
sk8freak123
Apr 16, 2009 8:13 AM
flstfse
Sep 30, 2006 7:28 PM
